Dura Lube, is it good to use or Not!?!
DUVALINCOLN
Tally
I recently brought some Dura Lube Advance Engine Treatment on sale and wanted to know your thoughts as to using in it for my 04 Lincoln LS V8. I know the formula itself is 10W-30 and you substitute that one qt. of Dura lube with your regular oil during chenge. I usually use 5W-20 from Motorcraft myself. Hwat are your thoughts. Is it good to use or not? Thank you for your thoughts.
Return it. If you're using synthetic blend (motorcraft) or full synthetic oil that stuff will only :q:q:q:q it up and you'll do more harm than good.
^Exactly. Modern synthetic oils are specially blended and already have adequate anti-wear and detergent properties. No need for extra miracles.
