Do you want to bleed the brake lines? If so read the last part of TECH ARTICLE Stop Tech SS lines instalation. Start with a turkey baster, about a $1 and suck out as much fluid as you can the add new brake fluid and start bleeding with farthest from the master cylinder and do all 4, RR, LR, RF and LF.
If you want to drain the fluid, my question would be why?
