stumpy
....dealer did not solder the splices...I've been having issues
Here are the diagrams
well if the PATS is not allowing the car to start some of the time, the who problem is with the immobilizer bypass...
the least likely suspect is that it has a loos wire either on the power, ground, or activation wire (it is least likely since most ford systems just have a harness that plugs into the brain)
if it works at all, then the chip inside of it has been programmed to the car so that is fine.
the most common issue is usually the placement of the RF antenna (the ring around the key cylinder) it is very touchy on its placement, so you need to make sure that you have it positioned perfectly. it needs to be tight around the OEM transponder antenna (black plastic ring around the key cylinder) and it cant be back too far, like behind the factory ring. I usually pull it as far forward as possible (closer to where the chip would be when the key is inserted) but obviously that's not entirely possible... then once i get it into a good spot that works well, I usually hot glue it into place.
if you continue to have problems getting the ring in the right place, I would swap it out for a different brand (like the Flashlogic FLCan) that instead of having its own antenna, it taps and solders into the PATS wires in the harness and then programs in either like a key or even cloning a key with their software.
I replaced the key antenna ring wire along with its black box, no change.
It works when it wants to. It will start every time if I leave a key in the ignition, so that tells me the harness is bad somewhere.
Hvac
