xford
Here are instructions to get rid of that annoying selt belt reminder chime (not that I am advocating driving without your seat belt fastened ) This is for a 2006 and I asssume will work for all Gen 2 and maybe Gen 1
Preparation:
1- Apply Parking Brake
2- Place gear lever in Park or Neutral (manual Trans)
3- Place ignition lock in the Off postion (key vertical on my vehicle)
4- Close all doors
5- Unbuckle the driver and front passenger safetly belts
Deactivating/Activating
1- Turn ignition to the on position (do not start the engine)
2- Wait until the safety belt warning lamp turns off (approximately 1 minute)
3- Note-Step 3 must be completed within 50 seconds after the seat belt warning indicator turns off. For the seating postion being disabled buckle then unbuckle the safety belt at a moderate pace 9 times, ending with the safety belt in the unbuckled position. After this the safety belt warning indicator will illuminate for three seconds 4- Within 10 seconds of the safety belt warning indicator turnin on, at a moderate pace, buckle then unbuckle the safty belt. This disables the safety belt minder chime for that seating position, if it is currently enabled. As confirmation , the safety belt warning indicator flashes 4 times per second for 3 seconds(in my case it was the airbag indicator). If you repeat the process it it will reactivate. For confirmation, the safety belt warning indicator flashes 4 times per second for 3 seconds, followed by three seconds with the indicator off, then the safety belt warning indicator flashes 4 times per second for 3 seconds again.
I had to follow these steps two times for it to work. You may need to do with the passenger seat belt as well....enjoy!
Preparation:
4- Close all doors
