Dashboard removal
Kstills
New Britain
I'm pulling the dash out of my parts car.
I've taken out all the bolts from the blend door fix thread. Steering column is out, center stack has been taken out, I found the thread for taking off the shifter, so that won't be a problem now. I spent 2 hours under the dash looking for and removing all the clips into the wiring harness that I could.
Question is, once the bolts are out (from the blend door fix) and the steering column is out, are there any other bolts that I need to remove, or is it just taking apart the wiring harness?
after that its all harness. there are a few small bolts around the right side of the stereo opening that are harness ground bolts, little 8 mm bolts and a few that hold the lamp out module on the top of the glove box opening other than that its all harness, and it sucks too, just be gentle!
Ok, thanks for the replys.
I agree, those wires are a pita, and my hands are all f'ed up from being inside the dash. But it's good to know that it's just a matter of tracing them back and undoing the clips.:)
One thing I have is time.
Once I get the dash out (and pull the wires for the CD changer) it's on to the engine. :)
