Dash light indicating light out stays on!
Lincoln LS
  1. tireman
    tireman Dedicated LVC Member
    1,208
    26
    May 15, 2005
    atlanta
    I found the third brake light out and replaced it. But the dash warning light stays on? Checked all the other lights, even the glove box, doors, interior, cig lighter, etc. etc. no lights out? Hmmm, checked turn, fog, high and low, trunk, backup, license plate, side markers, backup, all ok. Does it take time to update the warning light, I always thought it would turn off quickly. 01V6 base 206k miles.
  2. joegr
    joegr Dedicated LVC Member
    18,814
    1,240
    Dec 10, 2005
    Gulfport
    The warning light is instant, no memory. It will go out the instant you correct the problem (verified experimentally). Did you use the same bulbs, or LED? Did you check the parking lights?
    A good Ford specific scanner (Forscan probably can) can actually retrieve codes that indicate which specific bulb is the problem. Generic scanners can't.
  3. tireman
    1,208
    26
    May 15, 2005
    atlanta
    used the same bulb, not led. All lights checked. this car is always a challenge.
  4. FDR
    FDR Dedicated LVC Member
    1,767
    77
    Jan 20, 2014
    Central NJ
    Blinkers? Although that would cause hyperflash on the dash (outside blinks the correct speed regardless). I believe all it explicitly checks, on gen 1 at least, is front parking (3157 bulb only), front blinkers, rear blinkers, outer tail lights (3157 bulb only), and low brake lights. Low beams, high beams, fogs, high brake, 168-size front markers, and the 168-size tail lights have all been disconnected or gone out on me without a dash warning at some point. I have the V8 with the message center though, so it's easier to find the cause. I'm assuming it operates identically as the bulb-out lamp
  5. joegr
    18,814
    1,240
    Dec 10, 2005
    Gulfport
    That's my assumption as well. I think it is a reasonable one. While the bulbs you mentioned do not trigger a dash warning, several of them are actually monitored and will trigger a DTC if you scan for it.
  6. jmeecer
    jmeecer LVC Member
    32
    7
    Jul 10, 2014
    Saint Albans
    I do not put much faith in that dash message center. Had headlight out for weeks and the message center never caught it. Third brake light out for two months, well according to my wife who never told me, message center never caught it either. All I can say it "good luck."
  7. joegr
    18,814
    1,240
    Dec 10, 2005
    Gulfport
    Works As Designed
    Those are two of the lights that it does not monitor, so why expect it to mention them? Press status and it will name every light that it will warn you about. Connect a good OBDII scan tool and it will show a code for the headlight that is out.
  8. tireman
    1,208
    26
    May 15, 2005
    atlanta
    I noticed in the owners manual the the third light is not monitored, so I figured it was the one triggering the warning, so I replaced it. So now what do I have? Dash light is on and all lights work. Hmmmmm.
    Found an older thread that explains the situation perfectly. A bulb does not need to be out to trigger the fault light, it could be on it's way out. Look for a brighter bulb that the others or weaker bulb. It may take a month or more for the light to actually fail. Thank you for all the responses!
  9. tireman
    1,208
    26
    May 15, 2005
    atlanta
    Finally! A week or so later and the rear brake light 3157 craps out! Put a new one in and no more dash warning light. Great!
Share This Page
