Custom CAI
no heat soak down here.
Does that ribbed plastic tube do anything to the air flow?
No, there is only about 18 inches of that ribbed tubing with the angles I had to get around. The rest going all the way to the throttle body is 4" smooth piping. The 3" that fit through the stock hole under the air box choked the car at higher RPM's. I dremeled out the hole to fit 4" piping.
Is the diameter on the 03+ larger than the 2000-2002?
So are the intake kits from LSK 3" or 4"?
I could have swore they are 3".
Mind you I am talking of the first generation LS.
