Just bought a lincoln mark 1998 lsc, car was great when I checked it over no issues found anywhere, drove it for about 3 days and all the sudden it won't fire. Cranked while pumping gas no luck, only thing I did to it before this happened was change a really old fuel filter, Im thinking either
A. Fuel pump relay is faulty (going to swap after work today)
B. Antitheft issue? (not sure about this one wouldnt the car not crank?)
C. Crankshaft sensor (where is this located on this beast?)
or
D. Fuel reset switch in the trunk, checked it already and noticed the button can't be pressed down thinking that means its ok? noway to bypass it I assume either?
Anything I missed up there that could be causing my problem? Also would some of those things make the car throw some codes? I have an odb2 scanner so I plan to scan it after work to so I can narrow it down some more, very random, worst comes to worst probably the fuel pump died I tried listening for the pump and couldnt hear it
or
