Cowl Rivet Removal
orrgroup
St. Pete
Anyone know how to remove the tricky cowl rivet? Or, are they designed to break when removed?
Plastic bits? Just push down the center bit in it and then pull up, you may need a flat blade screwdriver if you nails are very short.
Don't break them. They are $14/ea here at the stealership.
Thanks guys. Will try to push the center. I have already broken one. Amazon had these for sale. box of 10...
http://www.amazon.com/CRL-Lincoln-G...J9C8/ref=sr_1_1?ie=UTF8&qid=1326047949&sr=8-1
You can something very similar for something like a $1.80 for four at Lowe's in the specialty fasteners. They are called 1/4" Vinyl Rivets there. I used those on my car when I found that the dealership had 1) lost 5 or 6 fasteners from the cowls covering the cabin air filter, etc.; and 2) lost the engine cowl and all it's fasteners.
