First off I have a 2006 LS with just under 50k km's on it. I have diagnosed a few problems and just want a second opinion on it.
1) My serpentine belt keeps falling off in really cold weather (-20 celsius or more). The first time in probably -30 weather, it comes off. I go to put it back on, all is well. Drove it around in -5 to -15 weather, and it was running fine no problems. Second time, same thing, cold weather and it pops off. It has poped off 3 times in total now. It pops off seconds after starting the car, and has some sort of "knocking" noise. Could be the belt hitting something? It looks to have poped off somewhere around the idler pulley. The first time I put it back on, I checked to see if any pulleys were wobbling or the tensioner was wobbling back and forth. No issues at all. Belt felt tight. I have a feeling it is the tensioner.
2) One day when driving home, the car kicked into failsafe model. Scanned the code and it came back as something to do with the electronic throttle control. I drove around the next day and all seemed fine, no failsafe mode, no lights on dashboard. Figured the problem went away, or the weather had some sort of effect (Slushy and windy that day). What I've noticed since is I am getting terrible mileage compared to before. Also yesterday I noticed at a constant throttle a few times the RPM's would just drop. This happened going around 80km/h. I figure this is the throttle position sensor.
3) When I put my serpentine belt back on and the air intake back on, I got a check engine light. Code read P0113 air intake too hot. I am going to buy some MAF sensor cleaner right away, to see if I might have dirtied the MAF sensor. After that I figure get a new MAF sensor.
Any suggestions would be very helpful. Thanks
