First Issue: Fuel Computer Data Error. Mechanic said that it was likely a fuel pump, so i had both the jet pump and the delivery pump replaced, but it didn't help. the fuel level indicator reads full when the tank is full, but 1/4 when the tank is empty and the car leaves me by the side of the road (yep, found that one out the hard way.) What other parts are there in this system to be replaced? What is the most likely to least likely?
Second Issue. Absolutely no transmission problems, when out of the blue the "E" and the "Check Transmission" message came on the message center for a couple of run cycles. It went away for a couple of weeks. Then I took out my Pioneer radio/gps nav system/cd changer/sirius radio/ipod adapter(which is on e-bay-shameless plug
) After i put the factory back in and buttoned everything up, i started the car and took it for a short drive with the old radio, etc. After driving it about a block or so, it say's "E", "Check Transmission" and the Check engine Light comes on.
after stopping the engine and starting it again, the gear shift indicator is normal, the fuel computer data error comes up, check engine light is on. then i drive car about 200 feet and the errors are back regarding the transmission.
The car drives and shifts perfectly, from slow speed to interstate speeds, even with the errors displayed.
I am thinking that maybe the message center is going bad??
Your advise would be greatly appreciated!!!! Need to sell the car to get the dreaded minivan to haul kids.
Thanks in advance!
Thanks in advance!
