Coolant Outlet Pipe - cracked
so here's my question. I waited for the engine to cool completely to start the bleed process and went out and found a pool of coolant by my front drivers side tire. Looking under the hood there was no tell tale signs of anything that I replaced leaking. (water pump, thermostat and thermostat housing, and water outlet tube) What could the cause be? even the bleed tube next to the fill reservoir was dry as a bone. In case I haven't yet, let me thank everybody for their help and insight with this procedure. I really do appreciate it.
Degas bottle.
He's retired and doesn't work at ford anymore, he hasn't posted since he told us he retired.
Anyone still on here? Ive got a Ls thats giving me hell. Very nice car gave 400 bucks for. 2002 v8. Overheated since i got it. When i got it, as long as i kept coolant in it, it wouldnt overheat. Eventually after replacing thermostat and flush, and it still over heating, I found a crack in the degas bottle. Replaced that and both hoses going to it. Still getting hot. So i use a block tester. All good on the block test. I'm about to replace the thermostat housing with the jag aluminum thermostat housing and I have yet another thermostat to put in due to the fact i cant guarantee it because its over heated since being replaced and because im already there in replacing the coolant flange... Any other ideas? I'll let yall know what i find after i install it tomorrow.
I'll post my number if i have to. If you got an idea and it fixes it ill seriously send money. Im lost on this thing and every shop ive taken it to are complete jokes.
