Oh I thought he'd already bought a pump and.. the rest..well uhm.. I struck out.
changing the water pump is ST00pid easy.
There are no accessories bolted to it, like ford used to do..hell there isn't even a "hose" connected to it..
hardest part of the job is gonna be refilling the cooling system afterwards.
pretty much it's gonna be.
Loosen, but dont remove the water pump pulley bolts (4 of them)
Then remove the belt and finish removing the water pump pulley.
Then take the bolts out of the water pump
Pull, wiggle and cuss at the water pump as you try to coax it out of the block.
Lube the water pump O ring gasket with Antifreeze and put the new pump back in.
When you buy the new pump, look at the impeller.
if you see exposed fins, dont get that pump that is the "old non improved style".
Look at the 04 navigator pump...it should be a direct replacement and should have the same improved impeller design as the 99-02 cobra.
Beware there are two different mod motor pumps, one has a long shaft and one has a short shaft.
I "believe" all the mark 8's were short shaft.
