Hot*Mk8
Well, with the cover aside, the stereo install got completed in a record... four-and-a-half days! I repaired the stupid triangle door trim pieces, relocated the air bag module and did a substantially better job on the head unit this time. Soldered the wires to the speakers because I hated the connectors that I got and I ended up soldering all of my crimp stuff, too, because I hate stupid connections. I don't want any of this stuff going anywhere! Also was thrilled to discover that the amps I chose, the Kenwood 8405 4-channel and Kenwood 8105D Monoblock, were plenty small enough to be located in the factory amp tray. I just dremmeled out the clips and extra plastic bits. Yippee!!! The only thing that shows is the JL Sub box. I couldn't use the capacitor, though, because it was too big. Doesn't matter at all even at the loudest volume I can take, so I couldn't be happier. I will NEVER do an install like this EVER again. Wow. The timing is perfect, though, because the 98 is still at the mechanic for the valve cover gaskets awaiting the new powder coated covers which are due today. I had the whole garage to hog up for five days! Oh ya. It sounds absolutely phenominal! Shew. Thanks for all the tips that were given to the other guy during his install. I pity him trying to run zero gauge wire through any openings in the firewall, however. My four gauge went very nicely through the mondo grommet on the passenger side and I ran all of the RCAs and turn-on down the passenger side as well. What was so awesome about using the amp tray was that I was able to create two grounds on the back seat framework that perform flawlessly. The wires are about 11" long.
I wouldn't recommend watching the video unless you're really, really bored either.
My iPhone is a tad over-matched with that much input, but you get the idea.
The beginning:
Routing 4 gauge wire in front of radiator and through the Mondo Grommet:
Adding RCAs and remote turn-on and removing the adapter for the factory wire harness:
Command central:
Passenger side speaker re-wire:
My interior pretending to be an exterior:
Backseat out and polishing rag acting as a cushion for the singular plastic screw that sticks up in the most inopportune location:
Cables into the tray:
I made a quiche at the start of the third day:
Wa la:
Lastly, the new battery connections:
VIDEO
The beginning:
Command central:
Wa la:
VIDEO
