RedHotMark96
I spent the weekend trying to swap the coils in, and had a pretty awfull time of it. The rears took ages, I had a pretty good share of problems, the tool was extremely difficult to use, took 3-4 attempts to get each coil compressed properly, then I couldnt get the tool out. I eventually figured out how to disassemble the tool inside the spring and take it out, but then had to reassemble it inside the spring and clamp inorder to lift the LCA so I could get the shock bolt in. Then it took an hour to get the tool back out with the LCA lifted by the shock bolt.
The fronts were going pretty smoothly until I tried to get the lower strut bolt off the driver's side. It absolutely wouldnt budge, I tried pb blaster, torching it and even using a sledgehammer. Ended up destroying the LCA bushing, and now I think I need a new lower control arm. I think I'm gonna have to have it towed in since I have no more time to fix this.
