#Jeff504lsv8
I have a #4 misfire and it started throwing a bank 1&2 over retarded will the a bad coil cause interference with with some other sensors? 2005 v8 ls
I hope you used Motorcraft for the replacement. Them aftermarket ones can damage the PCM.I know i have a bad coil I just now changed it we'll see if I still have those other code after I drive a while
