adubbbbbbz
My check engine light has come back i got the codes read
Cylinder Misfire Detected - Cylinder Number 4
Cylinder Misfire Detected - Cylinder Number 6
Probable Cause
1. Ignition System Fault-Spark(S), Ignition Wires, Coil
2.Vacuum Leak
3. Injector Fault
4. High Or Low Fuel Pressure
by the way i just changed all 6 sparks When i Had misfire in coil #2 which i also changed
what is affecting the coils and causing them to misfire
and with the probable causes how do i fix what ever is going on
Probable Cause
2.Vacuum Leak
3. Injector Fault
