ir1680
i have an 03 lincoln ls v8 w/ 80k miles
i've scanned the car with my otc scanner and i'm getting a code for ignition coil primary/secondary circuit error. or malfunction? cant remember. cylinders c,f,g,h. i can post the actual code numbers once i go check my scanner.
first off the valve cover gaskets were leaking. i've replaced the gaskets and spark plugs, and cleaned up all the oil. i clear the codes and the same ones come back. i tried replacing the last coil, which should be h. the code for that coil comes back on when i fire up the car????????? it runs ruff at idle and has a noticable miss. i checked the voltage at each coil and get 14.06volts with the car running.
i've been working on cars for over 10 years and i'm stuck. please help. guess i'm just an old school car guy. this is the first coil on cylinder car i've owned
