Camber Alignment after lowering my LS?
VanDarela
Long Island
I just lowerd my LS 1" and they "recomend" you get the camber alignment kit which is $50 and then $150 to install. It doesn't look like it needs it. has anyone lowerd their LS and accually done it? should I?
no - there are a couple of threads on this - the alignment kit does not fit very well and both people on the LLSOC that tried it remove it shortly afterwards.
Depends on ow much you are out - but typically with only a 1" drop - you'll be out about 1 degree. 1.5 degree is considered ok for street tires.
you will wear your inner edges out sooner.
Just dropped my car using an Eibach Spring Kit. No camber kit just went and got an alignment when I was all set.
