Brake Booster Operation Check
1. Check the hydraulic brake system for leaks or insufficient fluid.
2. With the transmission/transaxle (7002) in PARK, stop the engine. Depress the brake pedal several times to exhaust all vacuum in the system.
3. With the engine turned off and all vacuum in the system exhausted, depress the brake pedal and hold it in the applied position. Start the engine. If the vacuum system is operating, the brake pedal will move downward under constant foot pressure. If no motion is felt, the power brake booster system is not functioning. If slight motion is noted, the master cylinder o-ring is missing or out of position. Replace or reposition and perform tests.
4. Remove the vacuum hose from the power brake booster check valve. Manifold vacuum should be available at the check valve end of the hose with the engine at idle speed and the transmission/transaxle in NEUTRAL. Ensure that all unused vacuum outlets are properly capped, hose connectors are properly secured, and vacuum hoses are in good condition.
When it is established that manifold vacuum is available to the power brake booster, connect the vacuum hose to the power brake booster and repeat Step 3. If no downward movement of the brake pedal is felt, replace the power brake booster.
5. Operate the engine a minimum of 10 seconds at fast idle. Stop the engine and let the vehicle stand for 10 minutes. Then depress the brake pedal with approximately 89 N (20 lb) of force. The brake pedal feel (brake application) should be the same as that noted with the engine operating. If the brake pedal feels hard (no power assist), replace the check valve then repeat the test. If the brake pedal feels hard, replace the power brake booster.
If the brake pedal movement feels spongy, bleed the hydraulic system to remove air from the system. Refer to Hydraulic System Bleeding in «Section 06-06»
