Hey all... new to this forum, a Supercoupe convert from the SCCOA. Just picked up a sweet 1994 Markviii with 56,000 miles on it. It has a problem with the brakes that I think is the brake booster but I want to be sure before I tear into it. I have looked through A LOT of threads here but did not find the exact description and remedy of the problem.
When you press on the brake pedal, the pedal moves and I can hear a hissing sound inside the cabin, the car BARELY stops. The car also starts to stutter a bit and run rough when the brakes are pressed. I checked the check valve on the front of the brake booster and it is fine. So I assume I am looking at a bad booster. Did I miss a thread on the procedure for replacing the brake booster? Looks pretty easy but I am sure there are shotcuts. If I am only replacing the booster, will I have to get into the hydraulics at all or worry about bleeding the brakes?
The other question I have is about the ABS light. Would it be ON if the booster is no good? The ABS light is also on and I am not sure if there is another gremlin in there. Any help is appreciated.
