Hemihed426
OK guys I'm looking at replacing my brake booster and want some words of wisdom on the best way to go at it and should I throw a extra $20 in the collection plate for all the cuss words. I've been getting a pull to the right when I hit the brakes so I figured a caliper wasn't backing off the way its supposed to do so I replaced both calipers and the rubber brake lines. Prob still there, but when I was bleeding the calipers I had my son inside doing the brake pedal pump and every time he mashed the pedal the engine speed would change, indicitave of a vacuum leak which points me towards the booster. I haven't had time to really assess the job to know how hard its going to be, I guess I'll go ahead and change the master cylinder while I'm there since its the oem at 140K. Any thoughts would be appreciated.
BTW: for you guys that have a coil conversion buy the T-Bird brake lines, they are about $10 apiece cheaper and will bolt right up. That little ball for the height sensor won't do you any good anyhow.
