Brake Bleeding Procedure for abs any different?
89lincolnlscinoc
So Cal
I just want to make sure that I can bleed the brakes as one would normally do, or if I need special equipment because of the abs, I've heard some cars with abs have specific procedures
thank you
Seems I always had to run my Mark VII to get the brakes to bleed. With it running it would bleed normal. Without it running, it wouldn't work.
make sure you pull the brake line off at the caliper you dont want to push all the dirt through the abs sensors believe me
What? isn't the ABS sensor a electro-magnetic sensor the reads teeth off a ring gear mounted on the spindle?
