blend door repair
K-FAN
charlotte
hey guys as most of u know i went and replaced my blend door and no i go to turn on the ac/heat nothings working. u can here it kick on but no heat or ac blowing out what can that be i replaced bloth the blend motor and the grey arm and STILL TO :q:q:q:qING HEAT CAN SOME ONE HELP ME PLEASE
Is your blower unplugged? sometimes the connector gets loose & has to be squeezed with pliers ti fit snugly. 1st gens are on the bottom & 2nd gens are on the back of the blower motor. if you can touch the connector while it's on & wiggle it you'll know if it's the problem right away.
Run a eatc self test. OOORRR take it to the dillaship
plug the blend door motor back in, if you did, wiggle the plug on the blower motor, one or the other is screwed up.
thanks guys your the best the heater works but not blowing the full throttle with air max onheat or ac any ideas
Is this with a '94 like your name implies? If so it is a different situation than 2nd gens.
