revolutionaryconcepts
whats the difference between the ev6 & ev14 fuel injectors, other than casing? do the ev14's atomize better or respond quicker or what
why doesnt that suprise me, im thinking about swapping to the ev6 style seeing as how there is insane amounts of aftermarket sizing etc, If im thinking correctly the ev6 style nozzle actually sits lower in comparision to the seal
I need to compair an ev6 to the retarted ev14's in the gen 2's
total length
ev14 "medium" = 65.9mm
ev6 = 74.7mm
Injector nozzle end to top of lower o-ring
ev14= 11.45mm
ev6 = 8mm
aprox 3.5 mm lower
so I stand corrected the ev14 injectors sit lower into the intake stream then the ev6
lol im a complete lunatic ill, my efforts could probably always be invested better elsewhere but this is the kind of stuff that plagues my brain all day long, besides I beg to differ, an injector that has a distinct v spray pattern will atomize much better in an 4v engine than one with a standard uniform cone, due to the fact that its not being sprayed directly into the aluminum head, now would it make a noticable difference in a stock engine? No, well at least not likley, but I tend to obsess on making engines more specifically 4 valve engines run balanced, I built a 2.0l ztec in a 99 zx2 s/r for a friend of mine a few years ago that spun to 9.6k rpm, and trust me injector type, spray pattern, flow balance, and injection timing made a world of difference on that engine, matter of fact, once we got the right set of them in, we adjusted the cams and went from 8200 up to the 9600 peak, no big deal on our cars tho its more or less a hobby of mine, I think there is a lot of room for improvement with the finer things on these engines, after all its a ford.. they purposly de-tune everything anyway so who knows
