bad wheel bearing?? help
Are you sure mating surface of hub and back side of rotor is clean? I see lugs on there but those are all tight clamping rotor 100%?
O.O
Yeah I'd say that's not normal.. flip flop the rear rotors, double check
yeah, you might need a hub. looks almost like something is bent.
car ever been wrecked?
it has to be the bearing in my opinion because after looking closely at the cv shaft its moving just as far in and out as parts of the hub
Notice how the caliper bracket isnt moving. Bad hub bearing. Replace the bearing.
I don't know if you'd be interested, but I just found a box in my garage yesterday with all of the hubs that I removed from my car about 3 years ago. I don't remember the mileage, but there was nothing wrong with them when removed. Only removed so I could do the hub swap.
I'd let you have them for the cost of shipping. About $15.
Done with the job I had to replace the hub too, but the axle nut 250 Ft Pounds of torque my torque wrench is good for 150 ft pounds what to do?
