bad starter or crank sensor
98LSC32V
Bay Area
Was at the gas station in the 93 mark. Put some gas in it and then the car wont start. Doesn't crank over at all, nothing. What do you guys think starter or possibly crank sensor?
did you unplug the CPS Then plugged it back in and see if it changes? Its not your starter if the car is cranking
Starter solenoid, they get baked down there.
Check for power at starter when trying to start.
Crank sensor reads the crank, not allows the starter to crank. Its for ignition only. Your problem lies in the starter or power wires. As Ford Nut says though, they get baked down there and are prone to failure.
Same thing happened to mine at the salvage yard of all places! Turned out the connections at the solenoid were loose. Tightened everything down and it started right up.
My 98 Mark won't crank over if the Auto Lamp is activated. Also occasionally my Mark won't crank however after the third try it does. Is this the battery or the starter or the solenoid?
