#Jeff504lsv8
I pulled vacuum on the coolant system when it was cold an hot. Vacuumed all the coolant lines shut I'm guess I don't have a leak anet it sit for 10 minutes. I've out new t.stat Degas bottle new radiator an new fan still it runs at 205 with heater on soon as I cut the heat from 90 to 60 degrees it instantly climbs to 220 an fan is screaming I don't know if the aux pump fails will it make the engine over heat would any of y'all know. Thanks
