I noticed that you did not mention the thermostat as a likely culprit for no circulation so does that mean I don't really need to worry about changing it?
Do you not have an 01 V8 ?
... a different P/N ?
odd.
EDIT: thanks for the pic btw.
You guys are the masters! I will pull the relays. Interestingly enough, I didn't notice the pump running with the car off. Of course, I think it runs quiet as a mouse.
Riddle me this though. If the aux pump was getting power and staying on, wouldn't the coolant be blocked somewhere (i.e. DCCV, or all the way back at the T-stat) therefore creating higher pressure and overloading the pump and blowing a fuse? I wonder why this wouldn't have happened?
Joe's right on the A/C relay. I had only traced the aux pump wiring when I was working on my heating issues way-back-when. That one is a straight shot from the DATC.
Im assuming that just has a impeller inside and if not spinning will block flow. Can I just bypass the dumb thing? I would think the engine water pump probably has enough flow since mine is brand new. Thanks
... Can I just bypass the dumb thing? ...
The auxiliary coolant pump:
- provides heater coolant flow boost.
- has a secondary function of providing engine-off cooling.
The auxiliary coolant flow pump is electrically driven and provides increased coolant flow during low engine speed operation. The pump is also used to circulate coolant after the engine is turned off under certain conditions.
If the auxiliary coolant pump is inoperative, you will notice reduced heater performance at low speeds and at idle.
If too little coolant is circulated, the blower fan will pull enough heat out of the coolant and cause the heater core to get cold. (quicker)
In addition to providing assisted coolant flow for interior cabin heat at low RPM, this "dumb thing" also continues to assist with coolant flow cool-down after you walk away from it.
The only "dumb thing" here would be to bypass, remove or not replace it, you'll need it come winter!
Coolant Flow // Item #21 - Auxiliary coolant pump
The auxiliary coolant pump is declared faulty/defective/not working, when there is sufficient interior heat during higher RPM's but no heat during idle RPM's. In other words, when there is no heat from the vents during idle but lots of heat during driving speeds, it's time to replace the 12V BOSCH coolant pump.
Re&Re - OEM Auxiliary Coolant Flow Pump - GEN 1 V8
Your DCCV could be clogged or stuck closed. Use google site search for LS no heat. (I know, here we go again.) One guy even found that someone had shoved stoppers into his heater hoses instead of replacing a defective DCCV. Hot to the touch heater hoses don't always indicate flow. Everything in the engine compartment gets pretty hot.
During my no heat adventures, I had to replace both the aux pump and DCCV at the same time.
BUT then again, I also was replacing the entire cooling system at the time.
