BanginLS said:i dont know if the curves are right.. but that work to fit a custom intake on a 2002 LS?
either a lincoln LS v6
or a LSE v8
let me know pls.. i have both and am interested
That will not work straight up on your V6. You'll need to add two vacuum fittings and tap a hole for the air sensor. Also, you'd need to add a mounting bracket to the bottom to hold in place. It's not as straightforward as it looks unless you are Mr. Mack Daddy Mechanic.BanginLS said:so with this i can have an intake on my lincoln LS v6? how much shipped to 33185 florida?
GrayGhost1 said:That will not work straight up on your V6. You'll need to add two vacuum fittings and tap a hole for the air sensor. Also, you'd need to add a mounting bracket to the bottom to hold in place. It's not as straightforward as it looks unless you are Mr. Mack Daddy Mechanic.
GrayGhost1 said:It's not as straightforward as it looks unless you are Mr. Mack Daddy Mechanic.
You like that huh?mholhut said:Well then... just call me "Mr. Mack Daddy" Mechanic lol!!
GrayGhost1 said:You like that huh?
00ls5spd said:Gentlemen, where is this thread headed??.....
LMAO! I knew he was the ultimate Mr. Mack Daddy Mechanic!! :Beer01lssport said:To mholhut's house... He bought them for a Mack Daddy Mod.
mcafferty said:did you take the 40 or is this a biding thing? pm me and let me know i am not intrested in a biding war.
GrayGhost1 said:LMAO! I knew he was the ultimate Mr. Mack Daddy Mechanic!! :Beer
