Frogman
- Joined
- Jul 11, 2005
- Messages
- 6,914
- Reaction score
- 1
Does the word "overkill" mean anything to you audio freaks?
Yeap I have had so many weak systems. lol
This is just one of many I have built and yes it runs off of one 4 gauge wire to the rear batteries. Plays all day long wide open at shows. Doesn't blow fuses or burn up fuse holders nothing.
Just did a little searching and stranded 0 gage wire is good for about 150 amps.
150 amps at 12.6vdc (nominal battery voltage)= 1890 watts-20% for an efficient amp and you get roughly 1512 to speakers. That's peak, not continuous. That much power to a speaker or speakers continuously will turn your ears to mush quickly...guess what I am trying to get at is 0 gage wire in automotive situations is really not needed unless it's to the starter or alternator. It does make for a "good look" factor though. I won't say that I have 4 gigawatts of amplifier power. I only have about 300, peak. I have 10 gage wire on the amp through a standard household plug to the amp. I did this so that if I needed the trunk empty, I disconnect the RCA plugs, separate the electrical plug and remove the box and nothing shorts out.
i managed to finish wiring up the passanger side im really impressed at how they did the panels in this car and how easy things are if you take your time with it. i managed to get the rca's 90 percent run just needs to get up in the dash and i figured out how i wanna do it i just need to get the other stereo out reach down and fish em up and im good to go. im still at a loss for the power wire tho.
what kind of power RMS are your amp's the more power the amp's put out the more power / current draw well be on you cars alternator
. 4Awg wire from the battery back to the trunk with a fuse block and then 8Awg wire to the amp's is a good start but it all depends on what sizes amps you are going to use.
in my truck I have 4 runs of 0Awg two power two ground my sub woofer amp
has 2 4Awg power and 2 4Awg ground the amp is a DB Drive 2000.1 - it's 2000 watts RMS at 1Ohm but I run the amp at 000.33Ohm and get about 4500 watts
I have an 220 amp alternator it takes power to make power
What size fuses do you have in the amp, or in line to the amp?
I have 3 DB Drive WD 12" I can street beat my amp at .33 ohm
no fuses I have a 250 amp Circuit breaker
