Indo93
Hello new to the site, decided to make an account need help from tx. Ok start off. My 05 Lincoln ls v8 has been having over heating issues past 3 weeks just recent happend out of no where,i have a leak of coolant from the left side of tire underneath (driver side), it starts to bubble up in degas, and housing resivoir but no leaks near water pump or housing, it over heats in city & sometimes highway mostly city i drive (Arlington,tx) it does NOT at all over heat if i have the car running with the heater on full blast (heat is real hot)stays at mid of c and h but with ac on or off it starts to over heat? Any suggestions?. i changed the tstat, and water pump. Now (thinking the fan) and still over heating, i had a friend tried to flush the system for 20mins thru the bleeding valve. (Not sure if did it right) or maybe the coolant? Used the 50/50 mix green, plz help any info greatly appreciated.
