96_Lincoln_LSC
Went to get my studded snows on today, get to the shop, the aluminum rims they are mounted on corroded and caused the beads to leak, the stems were bad, took 30 min to get each tire rim cleaned enough to seal the beads, previous owner had put slime in the tire. I never knew it. looked like antifreeze when it was all said and done.. anyway, we go and put the car in the air, since I am having the trans swapped (hopefully weather permitting) Tuesday, never really gave much thought to anything else, Well, just for Sh!ts and giggles
I asked to check the D/S, man the u joints are so loose he's surprised I got as far as I did. Well hope my luck holds out till Tuesday as I still have approximately 200 miles left to drive over the weekend and Monday. I would have to assume this is originally caused buy the Trans going and sending the vibration all the way down to the shaft.
maybe its just coincidence that they both failed at the same time. either way at least I know neither one will be an issue in the near future.
I really Picked a hell of a time, I just sold off the 1 piece 93 shaft, two months ago. go figure. I'm not doing gears right now so I'll hunt for one later. I'm thinking of doing 3:73's when that time comes. I have the T-Lock and 3:55's sitting in my shed for a year now, just never did anything with them. Since I've already replaced the trans (soon to be anyway) I will save for the new ring and pinion and do this later on..
Let me clear this up a hair, I have Stock gears 3:27's its the LSC, I have a set of 3:55's in the shed on the Tracloc but if and when I decide to up the gears I think I may just go to 3:73's instead, don't really know if going to 3:55's are worth the effort of rebuilding the rear..
the 98 trans and updated TC may even be enough of a seat of the pants increase as it is, especially with the j-mod. so I may not even do the gears. trying to keep mileage.
anyway enough ranting and post whoring..
Have a good day..
Bill
Have a good day..
Bill
