airbag light
d_kelly_34
Kenosha, WI
my airbag light is blinking and after that it stays sudden i dont know what is wrong or whats even goin on with my car. how do i fix this and how????
If your horn works its not the "clockspring" Look up posts that deal with the wire under the seat the gets cut and turns on airbag light. Very common problem.
yes my horn works... what wires would i look under my seat for though and is it the driver seat?
See the "search" button up top of site. Use that to search airbag light. You will find all you need.
Your horn can still work and have a bad clockspring. The radio controls on the steering wheel are tied into the clockspring as well. If those are acting up it is most likely the clockspring. Check the pattern it flahes, should be a 3-2 or 3-6 I believe. One code is for the clockspring and the other is for a bad wire under the seat. Also if you type it into the search you should get all the answers.
