air suspension difference??
richduty455
South Jersey
got a quick question, is there any difference between the steeing for the air ride year to year?? Reason I'm asking is my 95 mark, if i load it with people drive around and we get out the car looks like a 4x4 when everyone gets out and stays that way for a bit, my 94 even though the compressor is off the second you shut the car off it lowers itself to normal height. I've left it sit for days and it stays normal, so i don't think the bags are leaking, is there different setting year to year?
if you load up the car, and then get out and it stays jacked in the air, your compressor isnt venting, the vent solenoid is either stuck , getting stuck, or completely junk, either way, change the compressor and your problem will be solved. thats the first tell tale sign of a bad venting solenoid, load it with weight, then take the weight out, if it stays jacked up, bad vent solenoid.
It will not vent until all doors are closed. But it should return to normal height with the car on or off once you close all doors. The system seems more "active" when the car is running though.
It will not vent with doors open so you dont land a door on the curb or something.
or get a spider valve and bypass that pos stock vent
