Air ride help needed
Lincoln Mark VIII
  1. Flanaman
    Flanaman New LVC Member
    3
    Jun 20, 2019
    Hamburg NY
    Hi there I have a 97 mark 8 which was slammed on the ground for about a year I just changed the compressor and dryer and now the compressor comes on for 2-3 seconds before shutting off and displaying the check air ride msg the compressor runs for a few seconds but will not fill the system and I'm now at a loss for what my next move should be
  2. slowmkviii
    slowmkviii Dedicated LVC Member
    5,570
    133
    Sep 28, 2007
    Elk River, MN
    Lift the car up to ride height before trying to fill the bags. Lift up by "frame" not suspension
    • Like Like x 1
    • Flanaman
      3
      Jun 20, 2019
      Hamburg NY
      Thanks for your reply I will try this as soon as I get home today and I'll post a reply on how it worked out
    • BILLBOATS
      BILLBOATS Dedicated LVC Member
      516
      17
      Sep 29, 2014
      Akron
      How did it work ? Did you try. Interested as I have same problem
    • BILLBOATS
      516
      17
      Sep 29, 2014
      Akron
      Dear Fladman, I can give you doable help. Today I pick up 2 home made ramps made out of 3"x3". treated wood. The wood was 6 ft long , sawed in hallf. He drew a diagonal line from corner to corner of each 3 ft part. Then sawed then to form 2 ramps. Then bolted them together with 6 inch lag screws. Now its doublw wide. Place the finished ramps infront ot the front tires. Find something like chain kink frnce for traction ahead of your rear tire. on both rt and lft rear wheels for traction because its goig to sping wheels once you give it gas. Then go straight up car ramps while put in drive with everything pointed straight. Proceed to drive up the ramps which can lift the Mark of the damn ground. You need 2 set of double wide ramps , 6 inches wide Put 2 cement block 2 in front to the end of each ramps to stop car from going further
    • Flanaman
      3
      Jun 20, 2019
      Hamburg NY
      Thanks for the suggestion Bill but I've already have figured out how to lift the car in pretty much the same way I replaced the compressor and relay only to find out the relay was the only problem so now I have an extra compressor lol the compressor comes on for 2-3 seconds bit won't lift the car I've tried lifting the car a few inches first and to ride height but still the same result and have tried everything in between still the same result I'm not sure why the car won't lift other then there's some kind of fault in the system which without a tester I haven't been able to decipher so I'm not sure what to do know considering just buying the conversion kit and switching it over to springs unless I can get this figured but even if I do it will only be a matter of time before I have to replace all of the bags and air struts which alone are as much or more then the whole conversion kit I am not sure what else I can do to get the air suspension to fill at the moment
    • joegr
      joegr Dedicated LVC Member
      20,040
      1,529
      Dec 10, 2005
      Gulfport
      The windows version of Forscan (free) and an $18 OBDII adapter should get you the diagnostics that you need. I'd want to keep the air ride.
    • BILLBOATS
      516
      17
      Sep 29, 2014
      Akron
      Did this get you back on track?
    • BILLBOATS
      516
      17
      Sep 29, 2014
      Akron
      Did this get you back on the right track?
    • BILLBOATS
      516
      17
      Sep 29, 2014
      Akron
      I have a rotunda air ride scanner
    • BILLBOATS
      516
      17
      Sep 29, 2014
      Akron
    Share This Page
