Thanks for the suggestion Bill but I've already have figured out how to lift the car in pretty much the same way I replaced the compressor and relay only to find out the relay was the only problem so now I have an extra compressor lol the compressor comes on for 2-3 seconds bit won't lift the car I've tried lifting the car a few inches first and to ride height but still the same result and have tried everything in between still the same result I'm not sure why the car won't lift other then there's some kind of fault in the system which without a tester I haven't been able to decipher so I'm not sure what to do know considering just buying the conversion kit and switching it over to springs unless I can get this figured but even if I do it will only be a matter of time before I have to replace all of the bags and air struts which alone are as much or more then the whole conversion kit I am not sure what else I can do to get the air suspension to fill at the moment
