Air has always worked great. Parked it. Washed it. Now no nothing.
98marklsc
kansas city
no fan no vent...nothing...my display reacts to what buttons i hit but it isnt turning anything on...I checked my # 9 fuse...good...any other suggestions?
Thanks!
i have read that the connector to the fan can work its self loose as well check that. you may have bumped it when vacuuming the car out
Blower motor control module got wet from water running down the cowl to inside the car. It might dry out and work tomorrow, and might not. Let me know if you need one, I got several.
thanks Gentleman,
I have my son till tues and a daily so i am gonna check into it then...that stands to reason Chargerrxr as it worked great prior to that...obviously there is the issue at the blower motor terminal and I will check that as well...thanks again for the help...
You were 100% correct chargerxr, I got curious since you mentioned that and just went and checked. everything is back. I guess i got too much water on the passenger cowl? is that where the fresh air intake is? and the blower control module too? i dont want it to get wet again of course. Thanks for taking the time.
Sometime you will need to remove your wipers and cowl, and seal around the fresh air intake. It comes loose and allows water to run in on pass side floor, and blower control module.
thanks chargerxr....I got the half the cowl off just jackin w it...obviosly need to take off the wiper to fully remove. i want to get some new screws as the replacement ones someone used on the cowl are tarnished and i want them black again haha will prob tear further into it tuesday.
Take 5 minutes.
