Air Conditioning Recharge??
Okay,Joe.........but I still wouldn't do it.The super cold fluid being incompressible as liquid, hitting a hot component is not what I'd take a chance on. don-ohio (:^)
It's not a hot component if it is working correctly...
Just added refrigerant to my 2005 Gen2 V8. Turn wheel full left. On my car there is a plastic cover (drivers side) It has 2 different screws that need removing. It helps to jack the car some for this. Once you remove this plastic shield there is another rubbery shield in the way. There is a a pop out connector on this rubber shield that you can pull out and move the rubber shield out of the way. The refill valve cover is right there now, remove it and attach your refrigerant bottle. Refill and enjoy the cold. BTW, I tested the air temp after refilling and it was 40.:cool:
