air compressor install
Replaced it on my 97 on saturday. Follow these directions and it works fine. I didn't even remove the mount. I just unbolted the 3 bolts, lowered the mount and pulled the compressor out. I didn't even remove the silencer. Also the rubber hose that is going to the compressor should not be pulled from the compressor itself because there is a clip holding it on. Try pulling it off the other side that is going to a black box.
http://www.justanswer.com/ford/1fh5i-procedure-remove-air-ride-suspension-compressor-97-mark.html
Good luck. Do you know how to remove the air lines?
