jmeecer
Hi all
Was told today when I had my LS in the shop for an oil change that I needed to replace my lower ball joints. My question is should I get replacement ball joints and press them in? Or should I replace the steering knuckle? I am planning on replacing the upper control arms this winter anyway bad bushings. Still thinking about doing the lower just do not know yet. If I decide to replace the lower control arms, should I just upgrade the lower ball joints to the 16mm ball joint and get new steering knuckles. Plan on keeping the car for a while. I was planning on replacing all four tie rods end (already purchased), sway bar end links (already purchased) and aftermarket sway bar bushing (not yet purchased) since I would have the front end tore about anyway. Any thoughts. Also need to replace front and rear brake pads and rotors. Having trouble finding a correct sway bar bushings for a non sport car. So, I guess the Rein part will not fit my car.
