Searched and found the below post.
www.lincolnvscadillac.com
My ABS traction control pump looks the same as the one pictured in the tread above. Looks like one of the bottom caps (or seals? not sure what these are called) rusted out.
In the thread above wana461 took the pump form a 97 and his 98 module and put them together without issue.
Hasn't anyone just replaced the caps or seals at the bottom of the pump?
Here is mine.
ABS Pump problems
So I just bought a 98 Mark Viii and the guy says he blew something off the abs pump. He has it pulled out so I'll post pictures later. If possible would like to save a bit of cash and fix rather then go through the hassle of buying another one. Hopefully you guys have some ideas.
Here is mine.
