ABS pump & ABS Control Module - 1998
14.6@97MPH
nj
I need some clarification on the correct ABS pump and correct ABS module for my car. As a reminder I've got a 98 LSC with the ABS/TC light with error code C1095. I replaced the relay, that didn't fix it.
- Does the ABS module for my car have to be from a 1998 Mark VIII only?
- Does the ABS pump for my car have to be from a 1998 only?
- Do used ABS pumps always come with the ABS module?
I 'think' I found the right part on e-bay, but the seller hasn't answered me back on whether it is both the pump and module.
Based on other posts from you guys, I think I'm going to get both a Pump and a Module even though my garage thinks it is the module.
Help!
Ken
It is possble to test the pump on the vehicle. When I removed my old pump I put power to the big red wire and grounded the black wire and the pump would not run. The new pump would run when powered. You should give that a shot. You can reach up in there and unplug the pump motor and jump power to it. Thats what I would try. But I still think your pump motor is dead.
