I blew the left front tire last night and it ate all the wiring and fender liner around it. The only thing I can't figure out from the junk 97 I took the wiring harness from is where the wires go on the ABS module. It snatched three wires off and I don't know where they go. I managed to fix fhe height sensor wiring and the lights on that side and reach the cruise actuator and hood release. The other problem I have is the odometer shows dashes and the speedometer doesn't move. Is that somehow involved with the ABS as well. So if anyone has the pinout for that I would appreciate it. Or if you know anything about About why the speedo doesn't work. Thanks
