smegun
im having trouble running the ABS bleed procedure quits after first command to depress brake pedal   *interrupted
when running the onboard tests the ABS test passes for connections ...all my tests pass except for P1000 but something must be up with running the bleed tool for it to dump and give me a red xbox saying * test interrupted (first request to depress the pedal )
there is a point you have to be ready bleeding the system that is bleeder open to perform
flashing traction control light solved by simply running
- Calibrate Yaw Rate / Lateral Acceleration Sensor
- Calibrate Brake Booster / Steering Angle Sensor
when i look into the programming section i get very little options to change wondering if im supposed to see more options only two modules have associated cfg files with the same name when backing them up all i get is what appears to be strategy numbers
using forscan 2.3.5 your saying 2.3.29 is better ? i got a gen1 LS sport with a 3.9 my forscan temporarily licensed
