ABS bleed procedure interrupted
Lincoln LS
  1. smegun
    smegun Well-Known LVC Member
    228
    4
    Aug 5, 2018
    deltona, fl
    im having trouble running the ABS bleed procedure quits after first command to depress brake pedal *interrupted
    when running the onboard tests the ABS test passes for connections ...all my tests pass except for P1000 but something must be up with running the bleed tool for it to dump and give me a red xbox saying * test interrupted (first request to depress the pedal )
    there is a point you have to be ready bleeding the system that is bleeder open to perform
    flashing traction control light solved by simply running
    - Calibrate Yaw Rate / Lateral Acceleration Sensor
    - Calibrate Brake Booster / Steering Angle Sensor
    when i look into the programming section i get very little options to change wondering if im supposed to see more options only two modules have associated cfg files with the same name when backing them up all i get is what appears to be strategy numbers
    using forscan 2.3.5 your saying 2.3.29 is better ? i got a gen1 LS sport with a 3.9 my forscan temporarily licensed
  2. BlacksonAudio
    BlacksonAudio Active LVC Member
    90
    73
    Sep 3, 2016
    Naples
    It won’t work. Been trying for 2 years
  3. smegun
    228
    4
    Aug 5, 2018
    deltona, fl
    wondering if forscan needs a adaptor for the adaptor like often equip adapters have a couple data lines swapped like d+ and d- are reversed do they need an adapter for the adapter .... koeo koer the software steps you through but errors result u codes alot maybe there not taking into consideration a technique like pats turning the key on and off a lot like fdrs or somthing ford might be doing to get past or excepting coding might have to take it to ford
    disconnnect my abs unit to see if i got oxidation you got a gen 1 post me some screen shots the demo shows a similar condundrum with a 2002 demo vehicle program section
  4. joegr
    joegr Dedicated LVC Member
    20,178
    1,569
    Dec 10, 2005
    Gulfport
    I think the Forscan just doesn't support the bleeding feature on the 1st gen LS.
    • Like Like x 1
    • Agree Agree x 1
    • smegun
      228
      4
      Aug 5, 2018
      deltona, fl
      just spits it out interrupted ? ,..... looking for another program ........ leaves you with little confidence ....... im on my third obd2 device i got the EX most recently
    • smegun
      228
      4
      Aug 5, 2018
      deltona, fl
      another program g-2 starts with turn ignition to position 2..................??
    Share This Page
