LongIslandLSE
I know once the abs comes on then the traction control will come on as well. I went and got the codes,here it is.
C1233-LF wheel speed sensor input missing
I am probably going to replace the sensor and hopefully be done with it. One question I have is does anyone else have problems with reading codes with the obdII. Aside from the Chassis (c code), body (b code) anyone have trouble reading powertrain codes (check engine light). Kept getting n/a when trying to read the fault.
