a new bentley key
I'm going to go with "No", mmkay. Did you not get the memo about the TPS reports?
However, a search for "Ford flip key 4 buttons" returns this: http://www.ebay.com/itm/For-FORD-Ex...Parts_Accessories&hash=item2a1f81294d&vxp=mtr
4-buttons, is a standard ford blank key, and lists Lincoln LS as compatible cars. $10 with $7 shipping and a 2-week wait from China. Not sure how you transfer the transponder chip though.
For a more cut-and-drive product there is this guy: http://www.ebay.com/itm/BRAND-NEW-L...Parts_Accessories&hash=item460316c9a1&vxp=mtr
Guess it boils down to how bad you want it.
high i want to use a bentley key in my lincoln ls just opening closing dors trunk and panic fuctions is it possible ?
well do you also want to carry around another key for the ignition, cause the one your looking at clearly says that it does not have any electronics inside it, no transponder so no starting the car.
easy to do? as they say in the advertissment???
it also clearly says that it works for chrysler and bently, not really sure why it would work on a lincoln.
also that key looks too cheap to use on a focus let alone a lincoln.
I'll just stick with my plain small key and smartphone, maybe even carry around the viper remote so that i can do more than even a OEM remote can
well do you also want to carry around another key for the ignition, cause the one your looking at clearly says that it does not have any electronics inside it, no transponder so no starting the car....
Actually, it doesn't have any remote electronics inside either. If you read a little more closely, it says that it is just a case. You put your own remote keyfob inside. As you can see, there is no way that the buttons for our remotes will line up with the button holes in the case.
its a mat, and you JUMP to conclusions!
I have the mat on my wall in my basement, my brother found me an office space kit and got it for me, the other stuff is on my desk.
We're gonna be getting rid of these people here... First, Mr. Samir Naga... Naga... Naga... Not gonna work here anymore, anyway.
And I said, I don't care if they lay me off either, because I told, I told Bill that if they move my desk one more time, then, then I'm, I'm quitting, I'm going to quit. And, and I told Don too, because they've moved my desk four times already this year, and I used to be over by the window, and I could see the squirrels, and they were married, but then, they switched from the Swingline to the Boston stapler, but I kept my Swingline stapler because it didn't bind up as much, and I kept the staples for the Swingline stapler and it's not okay because if they take my stapler then I'll set the building on fire
</thread>
uhhh yeah..... Peter.... I'm gunna need you to come in tomorrow.... and yeah, why don't go ahead and come in Sunday too... yeah
I'm not sure why you guys are so into having a key with buttons in it. The Lincoln key looks great. IMO the switch blade thing doesn't make up for the loss in look.
Of course this is my remote:
[/IMG]
I'm hoping that by the time I have to replace the LS, I can just get an RF id chip implanted and be truly key-less.
There is no way that the LS remote will fit in there and have the buttons line up with it.
Im confused. This one has all the guts in it already. It does not require the use of the cureent fob. I should be able to get this fob program the transmitter and have the key cut and be good to go.
This is from the listing:
DESCRIPTION:
Brand New Stylish 4 BUTTON MERCURY FLIP KEY (SWITCHBLADE) ALL IN ONE INTEGRATED REMOTE MODIFICATION (WITH RETRACTABLE KEY). Tired of your boring factory issued remote and separate key? Use this stylish (Volkswagen style with FORD emblem logo badge) 4 BUTTON retractable key instead. With the push of a button the key will flip out. when not in use, the key simply folds into the case (as shown in the listing picture) and avoids scratching other items (such as your smartphone) in your pocket or purse. This listing is for a FULL REMOTE including electronics and transponder chip and an uncut key so it can be cut to match your vehicle. This remote is made from high quality parts only. The materials used are more sturdy than even your factory issued remote and key and is not prone to the same wear and tear as your existing remote and key. The buttons will not wear down or rub off as your original does and the key loop is made of strong metal instead of plastic (like your factory issued remote). This will last for a lifetime and look like new for many, many years. This all in one unit will also work on FORD and LINCOLN vehicles listed in the compatibility section of this listing).
THIS LISTING IS FOR A FULL REMOTE (complete with electronics, chip, and uncut key). IT IS NOT ONLY FOR A REPLACEMENT CASE. The remote has four (4) buttons (lock, unlock, trunk release, and panic). This item ships from within the USA. Other sellers of the same item ship from overseas and you will end up waiting 4-6 weeks (rather than a few days) after payment to receive your purchase.
NOTE:
Please ensure that you currently use a FOUR (4) button remote. If you use the 3 button remote then you will need a different version. Please check our listings for the 3 button unit or email us (if you are not able to find it).
FREE REMOTE & KEY PROGRAMMING:
Once purchased (or received) please email us for the FREE REMOTE & KEY PROGRAMMING instructions. This all in one unit has a 2 part programming process. First, the remote must be coded to your vehicle. This part is entirely user programmable and you will save the dealer fee (approximately $80) to perform this process. Second, the key (and transponder chip) must be coded to your vehicle. In order to code the key (transponder chip) you MUST have 2 existing keys that are programmed to your vehicle. If you only have one key then you will need your dealer or a locksmith specialist to program the key (transponder chip) to your vehicle.
Tired of your boring factory issued separate remote and key? Use this stylish all in one (Volkswagen remote style) 4 button retractable remote key instead. With the push of a button the key will flip out. When not in use, the key simply folds into the case. Stand out of the crowd with this stylish conversation piece. Your friends will ask you where you got it and WANT ONE too.
so what happens when you sell the car, do they take it out or would it be reprogramable to the new car
I would think that it would work like the chip key does now. You don't reprogram the RF ID chip. Instead you reprogram the car. You reprogram the old one to no longer accept your RF ID chip, and you program the new car to accept your existing RF ID chip.
The RF ID chips in keys just have a unique serial number that each chip reports. (It reports in encrypted form to make it very difficult to copy.) The car is programmed to accept (or not accept) each unique serial number as needed.
