a couple rare junkyard marks
recently everything on the bottom end started leaking. So now from fixing the cosmetics, I am looking at dropping the K member out and replacing the oil pan gasket, the oil filter adapter gasket and replace the engine mounts while it's out. Also while the K member is dropped out I will probably replace the LCA's and do the front hub swap. I am just hoping the leak holds out till the weather gets a little nicer.
thx, I feel better: all I have underneath on my dd is fuel pump...for now
