Duck
Anyone know the length for an A/C delete belt? Friend has a 94 and the compressor locked up. She needs to use the car, but can't afford to replace compressor and flush the system right now.
Cut the stock belt, route the belt where it needs to go, mark the overlap point, subtract a little for the tentioner, measure.
You canI can't picture the belt routing you would use to skip the AC compressor without running a delete pulley. If you come up with something, be sure to post up a pic.
I got a good used compressor for cheap, $40 + shipping or you can pick it up??
